It is currently Tue Jun 25, 2019 6:07 am
PostPosted: Thu Oct 19, 2017 6:15 am
Dear experts,
As we know that distributed recording feature of iPi recorder could merge the master video and slave videos together automatically. But I'd like to know whether it is the same for automation adds-on. Should I use "command": "merge-videos" to merge videos together? Is it necessary to download the video files before merge? I did not find any download command in automation adds-on. Is there any suggested steps for this?
Thank you so much for your kind help.
Shawn
PostPosted: Sun Oct 22, 2017 1:08 pm
Currently, automatic download and merge is not supported in automation scenario. As a workaround I suggest you to make destination folders on slave PCs shared over the network. Then after recording stopped your program could:
  • either run merge-videos command with records in these shared folders
  • or first copy slave records to a local folder on a master PC and then run merge-records on local files
