It is currently Fri Oct 30, 2020 7:06 am
PostPosted: Wed Jan 31, 2018 4:05 pm
I've noticed some videos where instead of a targeted skeleton model. It targeted an actual model which is something similar like this!
https://www.youtube.com/watch?v=msRtIZX529Q [Notice the TF2 sniper model]
So I was wondering something. Is there a way I can target the actual model instead of the skeleton model? Or has this feature been removed for some odd reason?
PostPosted: Wed Jan 31, 2018 6:59 pm
To add a target character model, go to export tab and where it shows Default, use the drop down arrow and choose Select from file option and select one from your computer.
Usually a standard rigged fbx model will work, as long as it can be retargeted in iPi, but some models do have issues with retargeting properly and on export won't perform correctly, trial and error type thing.
I use the Autodesk Character Generator models for testing inside iPi, so I can see any glitches that may appear in a mesh, they work fine, but I have imported other models as well that worked fine.
As far as I am aware this function is still active.
