It is currently Mon Feb 24, 2020 11:03 am
PostPosted: Mon Jul 23, 2018 11:03 am
Hey guys,
I have 2 xbox 360 kinects running. I've captured some footage i'd like to do mocap with and have brought it into ipi. i aligned everything, however when I hit "refit pose" the character i've aligned myself with twists and contorts and is no longer perfectly aligned.
Can you advise? Not sure what exactly I'm doing wrong.
Also, when I use two cameras I find that one is operating at 28.2 FPS and the second one is at something very low and laggy like 1-2 FPS. Does anyone know how I can get both cameras to operate at 30FPS or something close?
THanks!
PostPosted: Tue Jul 24, 2018 12:06 am
Are point clouds from both sensors aligned when you see them in Mocap Studio?
Have you adjusted model dimensions and pose to an actor prior to hitting Refit Pose?
You may share your project file along with iPiVideo to let me take deeper look.
1-2 fps is no way usable. Try to connect the second sensor to different USB ports. Check that it works when connected alone to see whether the sensor itself isn't faulted.
Users browsing this forum: Google [Bot] and 1 guest
