It is currently Sat Jan 25, 2020 10:20 pm
PostPosted: Sun Nov 11, 2018 1:18 am
I just figured out that my desktop has only one USB 3.0 controller.
So, how can I get an additional USB controller?
PostPosted: Mon Nov 12, 2018 12:06 am
Would you mind adding more details?
PostPosted: Mon Nov 12, 2018 4:45 am
If your desktop has some free PCIe slots then you can easily add an additional USB 3.0 controller in the form of PCIe card. There are options with 1, 2 or even 4 controllers on a single card available in the market. Our website lists some recommended models of PCIe USB cards that work well with PS Eye cameras (look in "USB controllers" row in "For Web Cameras" section).
http://ipisoft.com/store/hardware/
How many cameras were you able to connect so far? Usually modern Intel USB controllers (which combine USB 2.0 and 3.0) can handle 4 cameras without a problem. So you probably need only 1 additional controller. However, you may decide to take 2-controllers card to have a room for upgrading to more cameras later.
FYI you can use more cameras in lower FPS modes, e.g 3 cameras per controller at 40-50 fps.
PostPosted: Mon Nov 12, 2018 1:59 pm
Oh. I wasn't aware that multi-controller USB cards existed. Learn something new every day. :)
Since I'm rebuilding my old workstation (mainly for use with iPi Mocap Studio,) and I'm limited to a micro-ATX board in this box, I'll certainly look into this. Thanks for the tip!
PostPosted: Thu Dec 19, 2019 2:12 am
Well, a 6 port USB hub pretty much worked for me, so try using that out, which might help.
Requirements and Features of Microsoft Office
