It is currently Fri Dec 13, 2019 8:22 pm
 Post subject: RTX 2080 Ti speed
PostPosted: Thu Dec 06, 2018 5:28 pm
Only through confirmation of another iPi user that recently purchased the GPU, the RTX 2080 Ti single GPU tracking speed using Low Res tracking speed and all Actor options maxed, the fps speed is performing at 7.5 fps and 16 fps with head tracking turned off on a 6-PS Eyes set up.
It would probably hit near, or at 30 fps for use with a dual Kinect v2 set up based on this information, but I don't know that the tracking of the depth cloud would keep up with that speed and not loose connection, would maybe have to use High Res tracking speed, so would drop off from max speed tracking ability, but still fast.
It would be interesting to hear from anyone using this GPU for tracking a dual Kinect v2 set up recording though.
Pretty impressive performance for 6-PS Eyes tracking and may get a little better as they improve the drivers.
 Post subject: Re: RTX 2080 Ti speed
PostPosted: Mon Feb 04, 2019 7:54 pm
Well, I do have an 2080ti and also a Kinect v2 cam. But I dont have a second one and even if I did, using two pcs for a capture is not very appealing..
Like Snapz said, if anyone has dual kinect v2 with 2080ti, and can produce same quality as the ps3 cams, I would be very interested in seeing the results..
Users browsing this forum: Google [Bot] and 6 guests
