It is currently Mon Feb 24, 2020 10:14 am
 Post subject: IPI and Motionbuilder
PostPosted: Sun Jan 17, 2010 1:17 pm
Anyone doing ipi Mocap and exporting into Motionbuilder for cleanup? any info / suggestions will be greatly appreciated.
Thank you
PostPosted: Fri Jan 22, 2010 3:09 am
me to, I would be very interested in other users experience in IPI to MB
PostPosted: Sun Jan 24, 2010 7:33 am
Me too, that would be fantastic..
PostPosted: Thu Mar 04, 2010 8:10 am
Me too...How has this product been as far as creating a decent bvh or fbx file???
New to this site...But an old timer for virtual reality way back when...
PostPosted: Tue Mar 16, 2010 11:18 am
I haven' t done too much testing yet, but my pipeline uses Motionbuilder as main tool for animation purposes.
Exporting MoCap Files from ipi to motionbuilder was not a problem. There is no difference to using bvh-files from other sources in Motionbuilder.
Use bvh-export in ipi and import this file into Motionbuilder.
In Motionbuilder you have to map some of the nodes by hand in the characterization process because the exported bvh-file doesn't seem to follow the standard MB-naming conventions. But you can extract a new naming template and use this in the future, so you have to do the mapping only once.
Next use this new character with the animation from the ipi bvh-file als character-input to your rigged Motionbuilder Character and you're done.
Use the motionbuilder tools to clean up the data from ipi if necessary.
Fairy
Users browsing this forum: MSN [Bot] and 7 guests
