It is currently Thu Jul 18, 2019 4:59 am
PostPosted: Tue Jan 11, 2011 11:22 am
In a recent post, it was mentioned that Jitter Removal can be reapplied with different settings without the need to retrack because it was being applied over the base motion data, non-destructively I presume. If that's the case, could we get a button on the panel that clears the Jitter Removal from a set range? I guess you might call the button 'Clear Jitter Removal' or 'Reset Mocap Data'.
The reason: I was wondering if this could be faster than applying Jitter Removal at level '0' to remove Jitter Removal from a range of frames.
Thanks in advance for listening.
Edit: you might be wondering why I want to do this. It's so I still have the option to export raw unedited data after I've already cleaned it up. This would only be necessary if I forgot to save a 'raw' version of my project file (which I did yesterday.) It might also be useful if a user was dissatisfied with his settings for CJR, and wanted to quickly start over with clean tracking data. (That happened to me too.) :)
PostPosted: Tue Jan 11, 2011 8:45 pm
Ditto here, same issue! same request!
Thanks!
