It is currently Fri Jul 03, 2020 6:10 am
PostPosted: Mon Mar 07, 2011 1:20 pm
Hello everyone, here are my Valve biped rig's for people that are working with the source engine,
it has all the Valve bones under the biped and you can apply mocap to it and export to the engine really quickly.
Recently asked questions:
Question : When I go to export its not working only the fingers are moving?
Answer : Right click the biped click "unhide all" now it will export the whole bone structure.
(note. check the layers tab for the layers the rig holds)
Why do I need this?
iPi Soft is great having a .SMD EXPORTER but if you wish to apply more the one capture through motionbuilder or edit the custom keyframes in 3DS MAX this is a more flexible option. Also with 3DS Max's motion mixer you can combine or blend multiple mocap files.
Why doesn't this work for "Left for Dead" models?
This rig is the standard Male rig for Source 2009 models, left for dead uses a diferent skeleton structure.
Biped
• Biped limb length must be set manually
• Curve editor support with TCB
• More 3ds Max tools
• Motion capture support: BIP, BVH, CSM
• Basic layer support
• Keyframed hand & feet IK
UPDATE
(v2.0)
(Download)
http://dl.dropbox.com/u/10798900/Produc ... IP_RIG.max
(v1.0)
Download
http://dl.dropbox.com/u/10798900/Produc ... d_Male.max
Details :
Half-Life 2 Episode 2 (source engine 2009) (standard bones)
Extension .max
If you found this useful please support me by leaving a nice comment!
Cra0kalo
Lead of Operation Reaper
http://projectreaper.com
PostPosted: Mon Mar 07, 2011 4:25 pm
Thanks for your contribution!
We added a link to your model to "Animation export and motion transfer" section in Wiki.
PostPosted: Wed Mar 09, 2011 4:21 pm
Thanks but you spelt my name wrong its "Cra0kalo" not "cra0calo"
Cra0kalo
PostPosted: Fri Mar 11, 2011 12:30 pm
I am sorry for misprint. Wiki is corrected.
PostPosted: Fri Apr 08, 2011 1:41 pm
Hi cra0kalo,
thank you for your rigg.
I have another rigg imported in MAX from an .smd file (Modern Warfare game).
The hierarchy is a little different.
Do you how can I copy one structure to another (not manually)?
PostPosted: Sun May 15, 2011 2:17 am
fferro wrote:
Hi cra0kalo,
Unfortunitly I dont kow how to do that, what do you need ?
Cra0kalo
PostPosted: Sun May 15, 2011 7:46 am
Well, I have a lot of character models and looking for a way replace their bone riggs for a character studio biped.
To skinning them with the new rigg also.
Each bone rigg has little difference in bones and poses.
I've seen BIPPY from Geoff Samuels, but this script works with riggs from MotionBuilder, not from Valve games.
PostPosted: Thu Jul 21, 2011 1:34 pm
hi, i try to load ipi soft .bvh mocap data onto max standard biped, and also the valve biped rig, but for both i get error:
following track names were found in the file and are unrecognized by biped:
HeadEnd, RHandEnd, LHandEnd,RToeEnd,LToeEnd
how can i avoid this error?
thanks for your help
PostPosted: Thu Jul 21, 2011 1:54 pm
You should export in 3D MAX Biped-compatible format:
http://www.ipisoft.com/en/wiki/index.ph ... _MAX_Biped
PostPosted: Wed Aug 03, 2011 2:45 am
Hi I am getting a good motion from the BVH, but the error causes the hands and feet to be deleted from the biped.
Error
The following track names were found in the file and are unrecognized by biped:
HeadEnd,RHandEnd,LhandEnd,RToeEnd,LToeEnd
I tried to export the animation as recommended but this problems continues to occur. Please help.
