It is currently Sat Dec 07, 2019 4:08 am
 Post subject: Posting video clips?
PostPosted: Tue Apr 07, 2009 11:16 am
Where is a good place to post video clips showing iPi DMC results? I noticed there was a section for posting "early work," perhaps that's the best place?
 Post subject: Re: Posting video clips?
PostPosted: Tue Apr 07, 2009 1:47 pm
You can submit videos to Video Gallery or New Members, whatever you think is more appropriate.
Please note that this forum is public, so make sure you do not post sensitive commercial details.
PostPosted: Fri Aug 14, 2009 3:15 pm
i just ttried to record single camera with IPI recorder, it crashes with 2 cams. I need 60 FPS. it only managed 5 at 320 x 240. when i play it back it omits the dropped frames and plays the clip back at 5 times the speed like some benny hill mocap night mare.
im thinking the only way getting 2 sources is to use 2 video cams with a stop watch visible in both and try and manually match up the start frames in premiere and edit that way. please advise
PostPosted: Sat Aug 15, 2009 11:46 am
What cameras do you use?
