It is currently Tue Feb 19, 2019 2:42 am
 Post subject: Kinect + Orbbec astra
PostPosted: Mon Sep 03, 2018 12:03 pm
Hello, can I use kinect and Orbbec astra at the same time with your software or I need to have two kinects or two Orbbecs?
Thanks!
Michal
PostPosted: Mon Sep 03, 2018 11:24 pm
Depends on the version of Kinect you have in mind. For Kinect v1 (for XBOX 360) the answer is "yes". For Kinect v2 (for XBOX One) - "no" due to incompatible resolutions between the sensors.
However we recommend not to mix different depth sensors whenever possible to avoid unexpected problems.
PostPosted: Wed Sep 26, 2018 10:31 pm
There will always be a compatibility issue when trying to use both. Try to check the web for this one.
Users browsing this forum: Bing [Bot] and 8 guests
