It is currently Fri May 24, 2019 5:00 pm
 Post subject: VIA VL 805 Chipset
PostPosted: Sat Feb 16, 2019 9:29 pm
Hello
This is my report about my experiment for VIA VL 805. I use 2 usb host controller with this chipset. And based on my research, still have bad frames in great number and frame drops. Camera is Visible, though. I use 10 meters usb 3.0 cable.
I think the problem is the driver from VIA itself, beside must be installed in Win 7 compatibility, it also have reconnecting issue, if you installed without win 7 compatibility.
 Post subject: Re: VIA VL 805 Chipset
PostPosted: Sun Feb 17, 2019 1:47 am
i have try to connect directly to usb host controller, and there is some fps improvement albeit small, from 32-35 fps to 38-39 fps. Still far from 60 fps
PostPosted: Mon Feb 18, 2019 3:39 am
Thanks for the info. Just to clarify - which cameras did you use, PS Eyes?
PostPosted: Mon Feb 18, 2019 10:54 pm
Yes, i using ps3 eyes. even though the chipset have updated to 805, still have the problem
