It is currently Wed Jun 19, 2019 10:45 am
PostPosted: Fri Mar 01, 2019 2:42 pm
I have a problem when installing their two software (iPi Mocap Studio, iPiRecorderSetup), since it requires me to have .Net, and even then I do not install the .Net version that it requires.
https://imgur.com/ZdhZvGa
https://imgur.com/HWmWxxR
Nor does it detect the version that I supposedly have installed, so I'm in a dilemma in making your software work, is it really for Windows 10?
https://imgur.com/TIz3dU7
PostPosted: Sat Mar 02, 2019 2:30 am
Yes, our software is fully compatible with Windows 10. I guess there's some problem with detection of installed version of .NET framework on your system.
What's your exact Windows version (listed in About pane of Settings app)? Windows 10 starting from Creators Update already has .NET Framework 4.7 or above pre-installed.
As a workaround, try unchecking .NET Framework item in the installer. If that's not possible, then use MSI installers of the programs. You can find the links on Release Notes pages in online docs:
http://docs.ipisoft.com/iPi_Recorder_Release_Notes
http://docs.ipisoft.com/iPi_Mocap_Studio_Release_Notes
PostPosted: Mon Mar 04, 2019 2:36 pm
search there and if you allow me to install the latest version 3.x of your programs. I detected the .Net 4.6 that it requires, so I do not have it installed in any way and I can not install 4.7 or higher ...
PostPosted: Tue Mar 05, 2019 12:44 am
Build 10240 (version 1507) is a pretty old build of Windows 10 dated by 2015. And indeed it's not supported by .NET 4.7. The earliest version supporting .NET 4.7 is Anniversary Update (1607, build 14393).
Is there a reason you cannot update your Windows 10 installation?
PostPosted: Sun Apr 07, 2019 2:38 pm
I get an error about the installer and here is my error message:
iPi Recorder 4.3.0.73
OS: Microsoft Windows NT 10.0.17134.0 (64 bits)
.NET: 4.7.2.461808
CPU count: 8
GC: workstation (Interactive)
Running in 64 bits
System.Configuration.ConfigurationErrorsException: Configuration system failed to initialize ---> System.Configuration.ConfigurationErrorsException: An error occurred loading a configuration file: Method not found: 'System.Xml.XmlNodeType System.Xml.XmlReader.get_NodeType()'. (C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Config\machine.config) ---> System.MissingMethodException: Method not found: 'System.Xml.XmlNodeType System.Xml.XmlReader.get_NodeType()'.
at System.Configuration.XmlUtil..ctor(Stream stream, String name, Boolean readToFirstElement, ConfigurationSchemaErrors schemaErrors)
at System.Configuration.BaseConfigurationRecord.InitConfigFromFile()
at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors)
at System.Configuration.ClientConfigurationSystem.EnsureInit(String configKey)
at System.Configuration.ConfigurationManager.PrepareConfigSystem()
at System.Configuration.ConfigurationManager.GetSection(String sectionName)
at System.Configuration.PrivilegedConfigurationManager.GetSection(String sectionName)
at System.Diagnostics.DiagnosticsConfiguration.GetConfigSection()
at System.Diagnostics.DiagnosticsConfiguration.Initialize()
at System.Diagnostics.DiagnosticsConfiguration.get_IndentSize()
at System.Diagnostics.TraceInternal.InitializeSettings()
at System.Diagnostics.TraceInternal.get_Listeners()
at System.Diagnostics.Trace.get_Listeners()
at iPiRecorder.App..ctor()
at iPiRecorder.App.Main()
at #=qUOU8IK2GtngUz1j7ZxZlqeT1zoKTLdSEqpi0GN87_Ro=.#=ztCsxY4s=()
PostPosted: Mon Apr 08, 2019 2:05 pm
extension shell won't install
PostPosted: Tue Apr 09, 2019 3:29 am
It looks like .NET framework is corrupted on your system. Try running .NET Framework repair tool.
https://docs.microsoft.com/dotnet/framework/install/repair
Users browsing this forum: FanTaz and 4 guests
