It is currently Fri Feb 28, 2020 7:44 am
 Post subject: Computer
PostPosted: Sun Sep 08, 2019 2:18 pm
Hi. Is it possible to use a MS surface pro3 to run 1 Kinect 2.0? It has usb 3 and 4 core cpup
 Post subject: Re: Computer
PostPosted: Mon Sep 09, 2019 3:18 am
no way
PostPosted: Mon Sep 09, 2019 3:34 am
We didn't test such setup ourselves. However, I've found this article which mentions using Surface Pro 3 with Kinect v2.
https://journals.plos.org/plosone/article?id=10.1371/journal.pone.0170890#sec005
PostPosted: Mon Sep 09, 2019 8:07 am
Thank you for the article. It will be helpful to me. I have successfully run the Kinect X Box One on my surface Pro 1. I guess my question properly stated is if I would be able to run the IPI Motion Capture software with it.
Thanks for responses!
PostPosted: Mon Sep 09, 2019 8:34 am
As soon as you're able to connect Kinect camera to your tablet, iPi Recorder should run fine.
However, motion tracking may be painfully slow with integrated Intel graphics. So I'd recommend to use a PC/laptop with discrete graphics for working with Mocap Studio.
PostPosted: Tue Sep 10, 2019 4:25 pm
I don't own a Surface Pro but I have a Wacom Cintiq Companion 2 Enhanced which is a similar tablet PC. The Wacom works with iPi Mocap Studio with a Kinect 2 so I'm guessing the Surface will too.
The Wacom's specs (recalling from memory so I might be slightly off. If I have time this evening, I'll check it.):
- i7 dual core
- 16 GB RAM,
- Intel Iris 6100 Graphics
- Windows 10
Sorry, I can't recall which USB controller this tablet has. Make sure the Surface Pro has a compatible one as listed in the iPi Soft Wiki.
Edit: I just read vmaslov's above post and I agree. The tablet is fine for recording motion but you'll want to do your tracking on computer with a better graphics card.
I should also add that, for Kinect 2 capture, the tablet's performance is adequate but not great. I can get an acceptable frame rate but I know the tablet is working extra hard to maintain it.
