It is currently Tue Oct 27, 2026 2:17 am
PostPosted: Tue Jun 05, 2012 1:53 pm
Version 2.0.0.12:
    Restored support for PSDRV3 drivers for Kinect on Windows 7, which was silently removed in the previous release. Sorry for inconvenience, folks.
    However, we strongly recommend to use Kinect SDK for recording with Kinects on Windows 7. This issue is discussed in http://forum.ipisoft.com/viewtopic.php?f=5&t=6078
    Check for version update from the application. To check, open the tools menu and click the CHECK FOR UPDATE button. If update is detected, you will be prompted to manually restart the application to perform an update.
    Currently, the auto update feature is configured so that checks for update are made once per day. It helps to reduce the start time of the application. If you've noticed an announcement about new release on this forum or elsewere, and you want to update ASAP - you can use the CHECK FOR UPDATE button. Alternatively (or for quick update from previous releases not having this button), you can download and run the updated installation program from our website.
