It is currently Mon Aug 24, 2026 8:20 pm
PostPosted: Fri Apr 02, 2021 1:06 pm
Heres what I made iPi soft from 2019 to today Maybe you like it ^ ^
-----used same mocap start------ ( 2 xbox one kinect (v2) + 3 moves )
S2FM Hatsune Miku End of world iPi Soft Contest Entry
https://youtu.be/jnf2dMxE-4c
Source 2 Hatsune Miku test render
-----used same mocap end------
Hatsune Miku in Vault as gman S2SFM 4K 60 FPS MAX SET ( 2 xbox 360 kinect + 3 moves )
https://youtu.be/iAswPLsAqG4
Hatsune Miku ipi Soft mocap singing and tutorial ( 2 xbox 360 kinect + 3 moves )
https://youtu.be/O_kJyoZcHIE
SFM Kylo Ren Starwars raw animation Test1 ( 2 xbox 360 kinect + 2 moves )
https://youtu.be/x6kBRPcpk9U
SFM Samurai Sakura Miku 4K 60 FPS MAX SET( 2 xbox 360 kinect + 2 moves )
https://youtu.be/ZtR3WxJUijc
SFM Winter is coming / Let it go Hatsune miku Snow miku 2018 2019 4K 60 fps max set ( 6 ps cams + 3 moves )
https://youtu.be/DI98PaMJEkk
Sfm Darth Vader Test2 ( 6 ps cams + 3 moves )
https://youtu.be/M-cLLSX6Z-8
SFM_vader Test1 ( 6 ps cams + 3 moves )
https://youtu.be/BoH8_ntfGyo
-----used same mocap start------ ( 6 ps cams + 3 moves )
SFM Hatsune Miku Celebration low gravity dance 4K 60 FPS MAX SET
https://youtu.be/naMxJ99VP24
SFM Hatsune Miku Summer sea sunset dance 4K 60FPS MAX SET
https://youtu.be/kmTsxp-kN7M
SFM Sector Sweep Snow Miku 2010/11/12/13/14/15/16/17 Dance 4K 60 FPS MAX SET
https://youtu.be/lL5LC1Jcs_c
SFM Hatsune Miku 6 modules show test animation ( 6 ps cams + 3 moves )
https://youtu.be/WXjGJ7gN7og
PostPosted: Sat Apr 02, 2022 5:03 pm
iPi Soft to Source engine 9 layer animation test
https://youtu.be/9jLD8nw_mZg
Behind The Scenes
https://youtu.be/znVVLIS2n8A
If you got question I will try to answer them.
