It is currently Fri Nov 06, 2026 11:19 pm
PostPosted: Fri Aug 19, 2011 4:14 pm
I have managed to create 2 Tutorials just for Daz 3D Users.
This covers creating motions in iPi and Transfering the motion to a import character.
Thanks and Cheers
http://www.youtube.com/watch?v=I0zixoVnfxI
http://www.youtube.com/watch?v=FuIc1RSCgOs
Both cover the same subject of transferring Motion for Daz3D
PostPosted: Mon Aug 22, 2011 1:12 am
We were unable to export collada from DAZ 4 like you had done. It always fails. From DAZ 3 (Victoria) it works, however, if I import that to iPi Studio as a target character and export the animation with it, it doesn't look right in DAZ. Maybe there is same kind of problem with the bone mapping that you had (there's no pelvis in Victoria's skeleton, though). The only way we have been able to get it work, is to export t-pose as a bvh-file from DAZ and use that as a target character in iPi Studio. The drawback of this method is, that you only see the skeleton of your target character in iPi Studio...
PostPosted: Mon Aug 22, 2011 6:07 pm
I watched the video and it looks like Bones is using DAZ Studio 4, which I believe has an updated Collada export from 3.
D|S 3's export wasn't a true Collada, but a "DAZ Collada" mainly intended to help get D|S scenes into Carrara (which failed).
PostPosted: Tue Aug 23, 2011 3:08 pm
Try assigning the Pelvis.
I exported out of Daz4 The first time. But I dont know how it worked.
I have since not been able to export a DAE file from Daz4.
But I do have the rig and the motion transfers fine from iPi to a BVH for DAZ4 Genesis figure.
Maybee its just the demo limitation?
PostPosted: Tue Aug 23, 2011 4:30 pm
First, sorry ppe, I misread your first post. You ARE using Studio 4.
Bones, the problem ppe is having is that he is using Victoria 4, not the Genesis figure as you are using. V4 doesn't have a pelvis bone, but Genesis does.
I'm playing around with Studio 3 and 4 as well as Michael 4, Vicky 4, and Genesis. I'll post if I figure out anything.
Addendum: for some reason, now I can't export a .dae from Studio 4 either. I think this calls for a bug report to DAZ.
PostPosted: Tue Aug 23, 2011 11:47 pm
We actually had to revert to DAZ 3 (and Victoria, since it doesn't have Genesis) because there's a plugin we need and it is not available for DAZ 4. Otherwise we would use Genesis as well. It was good to know about the pelvis bone, so thanks for that. I'll have to experiment with it so that I'm ready if we can move back to DAZ 4.
PostPosted: Wed Aug 24, 2011 8:05 am
What plugin?
PostPosted: Wed Aug 24, 2011 8:06 pm
Apparently DAZ is aware of the Collada bug and is working on it.
PostPosted: Thu Aug 25, 2011 4:24 am
I think it is called the Game Developer Kit.
Users browsing this forum: No registered users and 55 guests
