It is currently Sun Nov 08, 2026 11:39 am
 Post subject: OBJ sequence export
PostPosted: Sun Apr 23, 2017 2:57 am
Hi!
would it be possible to export the point cloud data as an OBJ sequence instead of baking each frame into one OBJ file?
Cheers,
Tim
 Post subject: Re: OBJ sequence export
PostPosted: Sun Apr 23, 2017 12:08 pm
Currently, when you select All frames in ROI for export, all frames are put in a single OBJ file as separate objects named frame_xxx. Do you actually need a sequence of OBJ files?
PostPosted: Mon Apr 24, 2017 2:00 am
thanks for getting back.
Yes, actually a sequence would be great - so each frame of ROI as a seperate OBJ. That's what most Visualisation Plugins can read.
As a workaround I export now current frames separately which get's a bit annoying for moren than 30 frames :)
Best
PostPosted: Mon Apr 24, 2017 2:42 am
Please name a few plugins you use so we can test export into a sequence.
PostPosted: Tue Apr 25, 2017 1:34 am
Trapcode Form, Plexus or Stardust are great After Effects Plugins which translate the OBJ-pointcloud into particles.
PostPosted: Tue Apr 25, 2017 2:24 am
Oh, I never thought to use those tools that way. Thanks for the info. Learn something new every day. :)
Users browsing this forum: No registered users and 29 guests
