It is currently Wed Oct 28, 2026 10:42 pm
PostPosted: Thu May 26, 2011 6:07 am
The free trial can not export animation?
but it says "Packed with all the features of full version, Trial Version allows you to learn and evaluate iPi Desktop Motion Capture™ system in your own time. "
Why?
PostPosted: Thu May 26, 2011 8:19 am
Unless they've changed their policy, I believe you can use the export animation feature for thirty days after installation. After that, you may still continue to evaluate all the other features.
It is, after all, a free trial version of the software. I don't see how you can expect more from a commercial product.
PostPosted: Thu May 26, 2011 2:30 pm
thx,greenlaw :)
But I just installed the "free version" for only 1 day,not after 30 days.
After I use "ctrl + E", it says "sorry you're working with project in restricted trial format that does not allow to export animation "
PostPosted: Thu May 26, 2011 2:57 pm
That's strange. I would write to them directly about it. I read elsewhere that their trial license is sensitive to significant clock changes. If this is what happened, I would ask them if they could reset the expiration date for you.
PostPosted: Thu May 26, 2011 7:22 pm
Sorry for this problem.
Did you change clock setting on your PC? Trial expiration may happen if you change the clock to a point in time in the past.
This can also be a bug. We plan an update of iPiStudio in a couple of weeks from now and we will try to fix it.
As a temporary solution, I suggest that you send us your project file (*.MocapTrial) and we'll export animation for you.
Users browsing this forum: No registered users and 12 guests
