| Can't export animation with free trial? https://forum.ipisoft.com/viewtopic.php?f=13&t=5079 |
| Author: | oaklee [ Thu May 26, 2011 6:07 am ] |
| Post subject: | Can't export animation with free trial? |
The free trial can not export animation? but it says "Packed with all the features of full version, Trial Version allows you to learn and evaluate iPi Desktop Motion Capture⢠system in your own time. " Why? |
| Author: | Greenlaw [ Thu May 26, 2011 8:19 am ] |
| Post subject: | Re: Can't export animation with free trial? |
Unless they've changed their policy, I believe you can use the export animation feature for thirty days after installation. After that, you may still continue to evaluate all the other features. It is, after all, a free trial version of the software. I don't see how you can expect more from a commercial product. |
| Author: | oaklee [ Thu May 26, 2011 2:30 pm ] |
thx,greenlaw :) But I just installed the "free version" for only 1 day,not after 30 days. After I use "ctrl + E", it says "sorry you're working with project in restricted trial format that does not allow to export animation " |
| Author: | Greenlaw [ Thu May 26, 2011 2:57 pm ] |
That's strange. I would write to them directly about it. I read elsewhere that their trial license is sensitive to significant clock changes. If this is what happened, I would ask them if they could reset the expiration date for you. G. |
| Author: | Michael Nikonov [ Thu May 26, 2011 7:22 pm ] |
oaklee wrote: But I just installed the "free version" for only 1 day,not after 30 days. After I use "ctrl + E", it says "sorry you're working with project in restricted trial format that does not allow to export animation " Sorry for this problem. Did you change clock setting on your PC? Trial expiration may happen if you change the clock to a point in time in the past. This can also be a bug. We plan an update of iPiStudio in a couple of weeks from now and we will try to fix it. As a temporary solution, I suggest that you send us your project file (*.MocapTrial) and we'll export animation for you. |
