It is currently Wed Oct 28, 2026 8:19 pm
 Post subject: Working with maya
PostPosted: Sun Sep 21, 2014 4:37 pm
Hello, first excuse my english.
I have few characters and few animations, i do with maya 2014 (no humanik), now i thinking in try something like ipi for new animations, but i don't want to do the work done again and all characters have diffent bone names for use with IPI.
my question its, can i use in any way the IPI generate animations with my already done stuff?
my knownledge with animations/maya ins't big, i work with maya/animation for few months.
 Post subject: Re: Working with maya
PostPosted: Mon Sep 22, 2014 12:47 am
You can transfer motions on any (biped) custom rigged character.
For non-standard bone names, you'll just need to setup the bone mapping manually on the Export tab in Mocap Studio.
PostPosted: Thu Sep 25, 2014 3:09 am
ok if i understand right at export i can change example LHAND to L_HAND right?
PostPosted: Thu Sep 25, 2014 3:33 am
Mocap Studio does not change joint names, but maps joints of built-in skeleton (with fixed names) to joints of your custom character (with arbitrary names). For example, you can map the 'LHand' joint to your character's joint named 'L_HAND'.
Mocap Studio includes pre-defined mappings for several widely used joint naming conventions. If your character follows one of those conventions, then you may not even need to set any mappings manually.
PostPosted: Fri Oct 24, 2014 2:21 am
then i suggest support (i don't known if have) for Unreal Egine 4 + ART bones.
https://docs.unrealengine.com/latest/IN ... index.html
