It is currently Sun Nov 08, 2026 8:20 pm
PostPosted: Fri Dec 16, 2011 4:47 pm
Hi I purchase basic license nad I can't run with dual kinect. My exact problem is this > http://www.ipisoft.com/en/wiki/index.ph ... ual_Kinect
My Device Manager shows this bad version. Both Kinects are plugged through one and the same USB controller. How can I change USB controller? I have 4 USB Port. 2 on the fornt connected by cable to motherboard and 2 one at the back on the root of motherboard. Can anyone help me?
My motherboard is: Intel Server System SR1560SF
system: Windows 7 home 64bit
graphic card: PNY quadro FX 3700
PostPosted: Fri Dec 16, 2011 8:37 pm
well there is a difference between the number of usb ports and the number of usb controllers
you need to switch one of your kinects from from one port to the other till you hit a diff
controller, that is if your computer has more than one but for the number of ports you have
it might not be the case.
PostPosted: Wed Dec 21, 2011 6:56 pm
Yes, you need to make sure its plugged into a diferent controller.
Check Device Manager under
Code:
Universal Serial Bus Controllers
Cra0kalo
Lead of Operation Reaper
http://projectreaper.com
PostPosted: Fri Dec 23, 2011 7:38 pm
ya,same problem here
can only let one of both at the same time.
PostPosted: Thu Jan 12, 2012 12:36 pm
Some laptops do have a 2nd USB Controller that is reserved for a docking station. BUT if you get the correct docking station it will often have USB ports that work directly with THAT 2ND controller!
Otherwise, most desktops will have 1 controller for the front USB ports and another for the back USB ports.
PostPosted: Sat Jan 21, 2012 11:19 am
yes it was problem with USB controller, I bought new laptop that has 3 USB controllers and now it works perfectly.
Users browsing this forum: No registered users and 40 guests
