It is currently Sun Nov 08, 2026 10:47 pm
PostPosted: Tue Jul 17, 2012 1:26 am
Hi I have a problem:
I set up the two kinects at about 90 degrees. Then I stand in front of one of them and make my T pose etc.
I then go into studio 2:
When I load the video for the t-pose, I am standing in the wrong position at at about 90 degree tuen to the screen avatar. Matching it up means I have to tun the avartar about 80 degrees clockwise to make it match the t-pose (this is the problem).
Question is:
(A) Should I stand square on to one of the kinects, if so which one?
(B) If I have stood in front of one of the kinects (camera 1), and it loads in the studio turned from the avatar, is they a button or something that will change the presetence of the video to use the other kinect eg change camera 1 to camera 2 as main?
OR what am I doing wrong?
PostPosted: Tue Jul 17, 2012 5:36 am
To minimize initial adjustments to actor model in Studio, you should strike the T-pose facing camera #1 (which is displayed first in Recorder when you are making a video). Actor model is also facing camera #1 in default position.
PostPosted: Wed Jul 18, 2012 12:44 am
Can you change the #1 camera in the recorder to #2, so you do not have to move the kinect, or swap the usb connections around?
PostPosted: Wed Jul 18, 2012 1:10 am
You can change cameras order by dragging their images at the Setup stage.
Users browsing this forum: No registered users and 76 guests
