It is currently Mon Nov 09, 2026 1:52 am
 Post subject: More than 6 ps3 cameras?
PostPosted: Thu Jan 31, 2013 8:36 am
I did a bit of searching in the forums here and was wondering if there is a technical reason for the max number of ps3 cameras is set to 6. Is it correct to assume the camera limit is set at 6 due to computer bandwidth?
Thanks for anyone that takes the time to answer.
PostPosted: Thu Jan 31, 2013 11:59 pm
Indeed, the bandwidth limit is the main technical reason. Another, more practical reason is that we do not believe that further increasing the number of cameras will give any considerable improvement in the accuracy of tracking.
However, before you, other users have managed to set up recording from 8 cameras at 50fps. So, we have implemented an experimental support for up to 8 cameras. We do not include this in the official feature list because we have not thoroughly tested such configuration. But you are free to try it.
PostPosted: Fri Feb 01, 2013 12:07 am
You may try to contact with the user who started this thread to discuss the usage of more than 6 cameras.
PostPosted: Fri Feb 01, 2013 7:32 am
Thanks for the reply and the info.
Users browsing this forum: No registered users and 73 guests
