It is currently Mon Nov 09, 2026 3:20 am
PostPosted: Wed Aug 21, 2013 6:25 am
Hi all.
I have a room that is about 16x22feet, 5x7 meters.
Im wondering if I should buy the kinetic or the cameras for it?
and what kind of capture space i can expect out of this room?
most of the info that if find is about the capturespace but not where the cameras/kinect are located in the room.
thanks
PostPosted: Thu Aug 22, 2013 11:19 am
Hello ariknorr,
Dual-depth-sensor configuration is optimal in your conditions. You'll be able to use both 90- and 180- degrees configurations. Expected capture area is about 2 by 2 meters.
You can also try to use 4 Sony PS Eye cameras, mounting all of them in the room corners at maximum height (near ceiling). In this case expected capture area is approximately the same, but this system is harder in setup, calibration and operation in comparison with dual-depth-sensor configuration. However foot tracking, head tracking and FPS are better in multiple PS Eye configuration.
P.S. Information about minimum required space can be found here ("Minimum Required Space" row in the 3d table).
