It is currently Sun Nov 08, 2026 8:21 pm
Post a new topicPost a reply Page 2 of 2   [ 11 posts ]
Go to page Previous  1, 2
PostPosted: Sun Nov 06, 2016 7:32 pm
Snapz wrote:
Was just a suggestion, if your getting good feet tracking then no need to do it, but I know it isolates and shows more of the feet when touching the ground...
Ah, I see. Yeah, that seems to be the nature of Kinect capture with either generation. The floor tends to 'eat' the bottom of the feet.
I think adjusting the floor height a little lower should minimize this issue.
However, my own solution has been to wear slightly bulky shoes or boots, that have a thicker sole. I usually wear a pair comfortable walking shoes with very thick soles that work perfectly for capture, and sometimes I wear these 'ug-style' boots, which are very soft and pliable for full mobility, and the extra bulk makes them easy to track.
BTW, I haven't tested the floor height idea above because my 'bigger shoes' solution has worked well for a couple of year. But now that I'm thinking about it, I should check if adjusting the floor height actually makes a difference.
Users browsing this forum: No registered users and 40 guests
