It is currently Sun Nov 08, 2026 4:15 pm
PostPosted: Fri May 01, 2020 3:48 pm
Hello everyone,
Does IpiRecorder discard background by ONLY RGB color instead of depth channel when using Azure Kinect ?
It seemed that the background remained if I take my video without recording the RGB color channel. I can’t discard it.
Is the principle of background removal is the same as that when I was using regular RGB Cameras ?
I am really confused. I need your reply very much. Many Thanks.
PostPosted: Sat May 02, 2020 4:09 pm
No, background is evaluated both for color and depth data. If you see the background with "Hide Background" option then a camera has probably moved since background evaluation.
PostPosted: Sun May 03, 2020 7:01 pm
I'm sorry for my expression ability.But this is not the point of my question.
The most important point is if I discard the RGB data , will I get the exactly same result of background removal when all the cameras do not move a bit?
Thank you very much.
PostPosted: Mon May 04, 2020 11:25 am
Background processing is independent for depth and RGB, so you'll get the same background removal for depth whether you do or don't record RGB.
Users browsing this forum: No registered users and 68 guests
