It is currently Sun Nov 08, 2026 11:46 am
 Post subject: Camera rotation
PostPosted: Tue May 07, 2024 11:04 pm
I'm attempting to calibrate with dual Kinect sensors, at 60 -90 degrees setup,
but when I import this into the studio, the file comes in with the cameras at opposite sides: 180 degrees.
There used to be a setting, if I recall, where there was a checkbox during import, to determine which setup is being used.
I can't seem to find this.
Any ideas how to correct this?
Thanks!
 Post subject: Re: Camera rotation
PostPosted: Wed Jun 12, 2024 12:23 am
You should perform calibration first, as described here
PostPosted: Sun Dec 29, 2024 10:22 pm
Try checking the camera orientation settings during the import process, or manually adjust the rotation angles in the software to correct the 180-degree discrepancy.
Users browsing this forum: No registered users and 88 guests
