It is currently Sun Nov 08, 2026 2:15 pm
 Post subject: Adjusting the skeleton
PostPosted: Wed Apr 29, 2009 7:45 pm
Hi all how do you manually adjust the skeleton(scale it) ?
PostPosted: Fri May 01, 2009 3:17 pm
You can use "Height" control on "Actor" tab to adjust actor height/scale.
Also, you should make sure your scene has correct scale. After calibration, you should use "Scale" control on "Calibration" tab to set correct scale for the scene. You should make sure that camera height and distance between cameras correspond to real-work distances after calibration. This is not very intuitive but is extremely important.
Users browsing this forum: No registered users and 67 guests
