It is currently Mon Nov 09, 2026 12:19 am
Post a new topicPost a reply Page 2 of 2   [ 14 posts ]
Go to page Previous  1, 2
PostPosted: Wed Sep 14, 2011 9:02 am
Could the center of origin be moved to the center?
Yes, I hope the fine folks at iPiSOft get a chance to help.
Ive never used blender. But perhaps now I should download it.
PostPosted: Wed Sep 14, 2011 11:45 am
Hi mrbones,
yes there exist a option to clear to origin, but then the bhv is destroyed. I try all what i know to fix this, but this can´t because i belive its a export problem.
Best Regards Radiac :)
Ps: If you try Blender, use 2.49b. Thats the same version that i use.
PostPosted: Fri Sep 16, 2011 6:55 pm
I always cut off the first frame too.
Maybe ifyou open the tpose in bvhacker and translate it down a few decimals, then test it, then repeat until you get the correct height or center of origin.
does that sound feasible?
http://www.truebones.com
PostPosted: Sun Sep 18, 2011 2:52 am
Hey MrBones,
hmm i dont understand the bhv Hacker program. How i can save my bhv? Must i use a registrated version?
To your Question. What is the result of your bhv, when you import this after editting with bhv hacker in Blender and you start to play this animation?
Is the armature on the same place like the position before the animation starts to run?
If not, then my problem is not fix.
Best regards Radiac :).
Thank you for trying!
