It is currently Sun Nov 08, 2026 8:20 pm
PostPosted: Mon Oct 24, 2011 10:41 pm
I am doing a research project with the iPi DMC. I had a few questions if anyone could help. One of my questions is about the motor. I took a video of a person climbing a ladder. When i used the motor to follow the person, the iPi DMC moves the ground level of the virtual scene up as well. This causes the actor to not be able to "climb" in 3d space. He remains stuck on the ground when he climbs. The second question is instead of the Blue grid background, how do you insert a background like in this video. http://www.youtube.com/watch?v=7ssb0ZN1MSA. A third question I have is how do you connect multiple cameras, in my case surveillance cameras to a computer so iPi DMC can use all the feeds together. What kind of cables do I need? Thanks!
PostPosted: Tue Oct 25, 2011 6:32 am
I'm pretty sure that to get any mocap; IPI's DMC expects that the ground plane doesn't move.
Unless your surveillance cameras have a frame rate of 120fps or better, go buy the PS3 cameras. They are so cheap and work.
Dale
Users browsing this forum: No registered users and 40 guests
