It is currently Thu Oct 29, 2026 1:29 pm
PostPosted: Mon Feb 18, 2013 2:06 am
Quote:
You also need a Bluetooth receiver. Bluetooth might already be built into your computer but if not, a simple USB stick will do. (I use a stick.)
hi Greenlaw, hi ipisoft.
Please give more details of bluetooth receiver that you're using, screenshot or model. sometimes it gave a little confusing when we need to choose from a lot various brand. which one will give better performance?
in other case, I've bought several kinds of "3m/5m extended cables", but my kinect fps just drop below 30fps.
thanks.
i love ipisoft, so much. :D
PostPosted: Mon Feb 18, 2013 2:36 am
I'm using a pretty old Kensington Bluetooth adapter. Sorry, I don't know the exact model or if it's even available anymore but I imagine you can get a better one for a bit cheaper these days. IMO, if you go with a good brand, you should be okay.
There was some problem with the Windows 8 Bluetooth drivers but I think that's been fixed in the current release.
If you're still uncertain about which one to purchase, do a search in these forums--iPi Soft and other users have posted what models they use with info on which ones work well with iPi Recorder and which ones don't.
PostPosted: Mon Feb 18, 2013 2:46 am
Regarding extension cables, make sure you use a USB Repeater cable, a.k.a, Active USB cable. This is NOT an ordinary USB extension cable--an ordinary USB cable's signal degrades with distance.
A Repeater cable typically has a box on the end that boosts the strength of the signal and allows you to daisy chain several such cables while maintaining the signal strength.
This is the type I use:
http://www.newegg.com/Product/Product.a ... 6812224004
You should know that they have a USB 3.0 version. I guess in theory it should be faster but I haven't tried one yet. Also, it costs quite a bit more than the 2.0 version and for shorter length.
http://www.newegg.com/Product/Product.a ... 6812224033
PostPosted: Mon Feb 18, 2013 5:01 am
I use
PostPosted: Tue Feb 19, 2013 2:37 am
Thank you Greenlaw & vmaslov, for your very quick response. it is very helpful.
"I hope iPisoft more widely known and used by many people in this world". :D
Users browsing this forum: No registered users and 115 guests
