It is currently Tue Nov 10, 2026 2:06 am
PostPosted: Thu Apr 11, 2013 7:48 am
OK. (Sorry if the question seemed too obvious)
no problem :)
Did you try to reboot OS?
Are there any problems shown in Device Manager when both BT adapters are plugged in (PS Moves turned off)? When you turn on PS Moves?
Try starting Recorder when all PS Moves are off, then turn them on one by one and hit the Refresh button each time. If that does not help, please also provide the trace log of Recorder from this run.
well, i did a reboot and tried everything you suggested. there are no problems shown in the device manager. unfortunatly after switching the PS-moves on one by one, all of a sudden, the controllers paired to the new adapter disappear. i'm starting to think that there might be a compatibility issue with the new adapter?
the procedure is the following:
1) i start the recorder with all motion controllers disabled. then i switch on controller one (paired to the new adapter) - refresh - shows up in the recorder as normal, working, device.
2) i switch on the second motion controller paired to the old adapter - refresh - shows up in the recorder as well (working, no problems)
3) i switch on the third motion controller paired to the new adapter - refresh - both controller that are connected to the new adapter show up, but have a HID error 121.
after refreshing again, the controllers paired to the new adapter are gone for good and dont show up in the recorder again. i also noticed that just before i get those HID errors, the "refreshing" takes considerably longer than normal.
anyway, tracelog attached. hope you guys can help me with this asap!
cheers and thanks!
File comment: tracelog
trace_20130411_164645.txt.gz [11.67 KiB]
Downloaded 841 times
PostPosted: Fri Apr 12, 2013 7:14 am
alright, we bought a new bluetooth adapter, and it seems that there was just a compatibility issue with the one i had before. with the new one i can connect all 6 PS moves without any problems. in case you're interested, the adapter that didnt work was a "Belkin - Mini Bluetooth Adapter" (USB).
cheers and thanks!
PostPosted: Fri Apr 12, 2013 7:42 am
Good to know you are through.
Please share your results with 6 controllers if you can.
