Gear, usb ports and joing rolls : )
https://forum.ipisoft.com/viewtopic.php?f=2&t=10220
Author:  amitr [ Sun Dec 29, 2019 3:37 pm ]
Post subject:  Gear, usb ports and joing rolls : )
Hello
I just bought the pro version and had a few questions please : )
1) is there a way to add join roll behavior ? so the twists between elbows and wrists will look more realistic?
If not, is there an easy way add it within the ipisoft after recording ? (i use ipisoft (new), maya and unreal. can learn motion builder if needed).
2) i did not bought gear yet. is there any advantage for a specific camera set in terms of final quality ? precision and minimal cleanup are the things important to me
3) I have Asrock x399 with ryzen TR 2950x. How many RGB cameras i can connect to it before ill need to add external usb card? (PCIE?)
Author:  vmaslov [ Sat Jan 04, 2020 4:17 am ]
Post subject:  Re: Gear, usb ports and joing rolls : )
Our software doesn't track wrist/forearm twists from cameras. It's possible to track wrist rotations using motion controllers. Rotation is applied to wrists (LHand/RHand joints) which usually works well with models having long-sleeved clothes. There is no option to distribute twist rotation between wrist end elbow. Probably this can be done in your animation software.
There's a detailed comparison of various camera configurations in our docs.
http://docs.ipisoft.com/Multiple_Depth_Sensors_vs_Web_Cameras_vs_Action_Cameras_Comparison
In short, RGB cameras provide the best accuracy with proper setup (camera positions, lighting, actor clothes).
We do not have experience with USB controllers in AMD chipsets. Thus I cannot tell for sure. Also, this depends on camera model and video mode you will use. Speaking of PS Eye camera, I think you'll be able to use at least 4 items at 60 fps or 6 at 40-50 fps. Unless there are compatibility issues between camera and USB controller.
Author:  amitr [ Wed Mar 11, 2020 6:23 pm ]
Sorry for late response. Thank you for the answer.
