PostPosted: Sat Apr 25, 2020 3:48 pm
Hello developers of ipisoft,
How to calibrate the Quadruple Azure Kinects in four-corner setup method with one single white card board ? There are only samples about double Azure Kinects calibration with card board in the official documents.
Could you please explain that calibration Quadruple Azure Kinects with card board ?
Thank you very much.
PostPosted: Sun Apr 26, 2020 1:43 pm
Board calibration is only supported for 2 depth sensors. For greater number a light marker calibration should be used.
PostPosted: Wed Apr 29, 2020 5:41 pm
I think the board calibration is much easier and effective for me. Take two videos each with two sensors separately and combine the two ipiscene file with notepad editor manually. Will this be feasible solution ?
PostPosted: Fri May 01, 2020 12:43 pm
No, because two pairs of sensors won't be calibrated with each other. And camera coords will be in different coordinate system for different pairs.
PostPosted: Mon Jan 16, 2023 12:29 am
How many photos did you take with each camera of the calibration board? Did the pictures show the board from several angles? wordle
