| calibration Quadruple Azure Kinects with cardboard ? https://forum.ipisoft.com/viewtopic.php?f=2&t=10257 |
Page 1 of 1 |
| Author: | cc8boy [ Sat Apr 25, 2020 3:48 pm ] |
| Post subject: | calibration Quadruple Azure Kinects with cardboard ? |
Hello developers of ipisoft, How to calibrate the Quadruple Azure Kinects in four-corner setup method with one single white card board ? There are only samples about double Azure Kinects calibration with card board in the official documents. Could you please explain that calibration Quadruple Azure Kinects with card board ? Thank you very much. |
| Author: | vmaslov [ Sun Apr 26, 2020 1:43 pm ] |
| Post subject: | Re: calibration Quadruple Azure Kinects with cardboard ? |
Board calibration is only supported for 2 depth sensors. For greater number a light marker calibration should be used. |
| Author: | cc8boy [ Wed Apr 29, 2020 5:41 pm ] |
vmaslov wrote: Board calibration is only supported for 2 depth sensors. For greater number a light marker calibration should be used. I think the board calibration is much easier and effective for me. Take two videos each with two sensors separately and combine the two ipiscene file with notepad editor manually. Will this be feasible solution ? Thank you very much. |
| Author: | vmaslov [ Fri May 01, 2020 12:43 pm ] |
No, because two pairs of sensors won't be calibrated with each other. And camera coords will be in different coordinate system for different pairs. |
| Author: | mariahcarey [ Mon Jan 16, 2023 12:29 am ] |
How many photos did you take with each camera of the calibration board? Did the pictures show the board from several angles? wordle |
