ipisoft.com
https://forum.ipisoft.com/
Rotate Ground Plane
https://forum.ipisoft.com/viewtopic.php?f=2&t=10322
Page 1 of 1
Author:  RuBoChan [ Mon Sep 21, 2020 4:23 pm ]
Post subject:  Rotate Ground Plane
Is there a way to rotate the ground plane? It seems like no matter what angle the camera is at, iPi Studio automatically aligns my scene with the ground slightly slanted. I have looked for an option to orient the scene manually to improve my results, but no luck so far.
Author:  vmaslov [ Tue Sep 22, 2020 12:57 am ]
Post subject:  Re: Rotate Ground Plane
No, there's no way. Incorrect detection of ground plane when using depth cameras can be caused by insufficient area of the floor visible to a camera. Ensure that the floor surface occupies at least 1/6 of the frame area within its lower part, there is no much yellow on it (unknown depth) and there are no unnecessary objects on the floor.
Author:  Greenlaw [ Wed Sep 23, 2020 11:09 am ]
Also, if your floor surface is very shiny and reflective, this can cause errors (indicated yellow regions.) In this case, it helps to throw a carpet on the floor. (It's what I have to do in our living room.)
In general, you want to avoid a lot of shiny reflective surfaces in the background. If this describes your space, try covering these surfaces (i.e., large mirrors, windows, etc.,) with a blanket or large non-shiny fabric.
http://www.phpbb.com/
