| the largest feasible capturing area with 2 kinects https://forum.ipisoft.com/viewtopic.php?f=2&t=10464 |
| Author: | Hedii900 [ Wed Apr 27, 2022 6:14 am ] |
| Post subject: | the largest feasible capturing area with 2 kinects |
hey everyone, I have a dual kinectV2 system and I want to record people's simple straight walk and 1 turnaround for biomedical purposes. so u see the gestures aren't too complicated but I need fairly good accuracy. now I was wondering what is the maximum capturing area with dual Kinect system? and with which camera setup will I achieve that (180/90)? my room is rather large 8*6 meters so I don't have problems. I really appreciate it if you could help me. thanks |
| Author: | vmaslov [ Thu Apr 28, 2022 1:19 pm ] |
| Post subject: | Re: the largest feasible capturing area with 2 kinects |
Hi The capture area for Kinect v2 is typically about 2.5x2.5 meters. As the distance between a camera and a person should be in the range from 2.5-3 m to 5-6 m. Closer, a person may not fit full-height. Further, the quality of depth data degrades substantially. As you mention the full turnaround motion, I'd recommend a 180 degrees setup. You can get the max distance of ~3.5-4 m if a person walks by the diagonal between two cameras, not straightly from one to another. |
| Author: | Hedii900 [ Thu Apr 28, 2022 10:49 pm ] |
vmaslov wrote: Hi The capture area for Kinect v2 is typically about 2.5x2.5 meters. As the distance between a camera and a person should be in the range from 2.5-3 m to 5-6 m. Closer, a person may not fit full-height. Further, the quality of depth data degrades substantially. As you mention the full turnaround motion, I'd recommend a 180 degrees setup. You can get the max distance of ~3.5-4 m if a person walks by the diagonal between two cameras, not straightly from one to another. thank you so much, i really need 3.5 meters walkway, it would be awesome. and i was wondering in the 180 setup the distance between cameras should be 6m? |
| Author: | vmaslov [ Fri Apr 29, 2022 6:53 am ] |
The ideal distance to maximize the capture area is 7-8 m. |
| Author: | Hedii900 [ Fri Apr 29, 2022 10:45 am ] |
vmaslov wrote: The ideal distance to maximize the capture area is 7-8 m. thank you so much |
