| Kinect 2 and 360 at the same time https://forum.ipisoft.com/viewtopic.php?f=2&t=10516 |
Page 1 of 1 |
| Author: | nicbin [ Mon Jan 02, 2023 6:25 am ] |
| Post subject: | Kinect 2 and 360 at the same time |
Hi, i just bought a kinect 2 as a second camera to have a better mocap, but, i don't be able to make it work on Ipi Recorder 4 with a 360 and k-2 at the same time. There is a way to fix that? There is a message when i selected 2 cameras, the message "Selected cameras are not compatible". Thank you |
| Author: | andrew [ Fri Jan 06, 2023 4:54 am ] |
| Post subject: | Re: Kinect 2 and 360 at the same time |
Hello, All cameras must have common video modes (the same resolution and FPS) to be used simultaneously. Unfortunately, Kinect 360 and Kinect v2 doesn't have similar video modes. |
| Author: | nicbin [ Fri Jan 06, 2023 5:45 am ] |
andrew wrote: Hello, All cameras must have common video modes (the same resolution and FPS) to be used simultaneously. Unfortunately, Kinect 360 and Kinect v2 doesn't have similar video modes. Yeah, i found a lot of information about that... now i have another problem. I bought a second 360 camera, but in my laptop i can't use 2 cameras at the same time because USB controler. There is a solution for that? (I have to try in my desktop pc yet) |
| Author: | andrew [ Sun Jan 08, 2023 1:46 am ] |
nicbin wrote: I bought a second 360 camera, but in my laptop i can't use 2 cameras at the same time because USB controler. There is a solution for that? Hello! You can use distributed recording. |
