It is currently Sun Nov 08, 2026 3:08 pm
PostPosted: Mon Jan 02, 2023 6:25 am
Hi, i just bought a kinect 2 as a second camera to have a better mocap, but, i don't be able to make it work on Ipi Recorder 4 with a 360 and k-2 at the same time. There is a way to fix that? There is a message when i selected 2 cameras, the message "Selected cameras are not compatible".
Thank you
PostPosted: Fri Jan 06, 2023 4:54 am
All cameras must have common video modes (the same resolution and FPS) to be used simultaneously.
Unfortunately, Kinect 360 and Kinect v2 doesn't have similar video modes.
PostPosted: Fri Jan 06, 2023 5:45 am
andrew wrote:
Yeah, i found a lot of information about that... now i have another problem. I bought a second 360 camera, but in my laptop i can't use 2 cameras at the same time because USB controler. There is a solution for that? (I have to try in my desktop pc yet)
PostPosted: Sun Jan 08, 2023 1:46 am
Hello!
You can use distributed recording.
