 Post subject: HIGHER FRAME RATES
PostPosted: Tue Jan 26, 2010 4:55 pm
Ello!
I haven't actually tested the software cuz it doesn't work on my old PC.
But! I wanted to ask something either... ways....
If! I used cameras with higher framerate speeds, Say - 100 FPS to 500 FPS, would that increase the performance of IPIsoft?
Has anyone tested this?
If so, How much does it increase the performance?:)
And bytheway, How much would such and such a camera cost? I haven't actually looked into it! either...
Thanks!
Bye.
Dennis James.
 Post subject: Re: HIGHER FRAME RATES
PostPosted: Fri Jul 11, 2014 11:41 am
still a question I can't answer. Would iPi work with higher framerates? I mean sure you'd get problems with the usb connection. But would it work in theory to use faster cameras? Perhaps use some external hardware to record the videos and put that into ipistudio? Mr iPi what would you say? :)
PostPosted: Fri Jul 11, 2014 12:32 pm
There are no off-the-shelf cameras with framerates higher than 60 fps. There is no limitation regarding fps, but we have not tested the system with professional cameras.
