It is currently Mon Nov 09, 2026 4:15 am
PostPosted: Thu Jul 10, 2014 7:14 am
hi there,
has anyone any experiences with using motion controler while capturing with 4 PS eye's?
So i've got a quite well working ps eye setup and want to add motioncontrollers for the head and hands.
is it possible to capture/track everthing within one capture? like connecting ps eye's, a kinect and 3 motion controler together
in one single capture?
have a nice day,
jonas
PostPosted: Thu Jul 10, 2014 11:07 am
Setting up the motion controllers for PS Eye isn't any different from setting it up for Kinect--you just need a compatible bluetooth adapter. You only need one adapter for head and two hand controllers.
I use a dongle version attached to a USB cable so I can keep the adapter close to the capture space. I believe this helps it receive a stronger signal from the controllers and eliminates any interference that may come from the computer.
PostPosted: Fri Jul 11, 2014 6:00 am
thanks for your quick reply.
So that would mean i dont actually need a kinect to capture the motion controllers?
Only a bluetooth for my pc and iPi will recognize the controllers?
cheers,
Jonas
PostPosted: Fri Jul 11, 2014 4:53 pm
That's correct, the PS Move and Wii-mote Plus motion controllers are a completely separate capture devices and have nothing to do with Kinect technology. You can use them with either PS3 Eye cameras or Kinect so long as you have Bluetooth capability in your computer.
Users browsing this forum: No registered users and 87 guests
