PostPosted: Sat Mar 19, 2011 12:15 pm
i have 4 pseye cams that i was recording via my laptop through ipi recorder
i could only record at 320x240 otherwize i would have major dropped frames
i was using the raw function and my laptop is pretty modern 4 core with 8 gigs of ram and dual hard drives....
and the cameras were plugged directly into the laptop for testing purposes (i.e. no usb extensions)
i was just surprised that it could not record 4 streams of 640x480 even at 30p without dropping a lot of frames....
to get 60 fps i can only do 320x240
is this typical or should i troubleshoot something....is 4 cams at 640x480 60fps raw possible on a good laptop
thanks
PostPosted: Sun Mar 20, 2011 7:28 am
read:
http://www.ipisoft.com/en/wiki/index.ph ... ontrollers
You might have only one or very low performance usb controllers.
