It is currently Sun Nov 08, 2026 11:29 pm
PostPosted: Fri Aug 05, 2011 2:19 pm
In the post from Radiac i asked if with two Eye, i can use ipisoft.
for me, i meaming one in front and the second on the right or left side .
possible ?
thanks
PostPosted: Fri Aug 05, 2011 4:42 pm
This is just my opinion but, while I think it's possible to use two cameras, accuracy will suffer and the type of motions you can capture will be limited, probably a lot more than with Kinect. A minimum of four PS3 Eye cameras is recommended but I think even three cameras will give you much better results than two.
Considering the cost of the iPi DMC software, you may as well just get four PS3 Eye cameras or invest in the Kinect only version. The Kinect only version will get you up and running with good results quicker if the motion data you need to capture isn't too complex.
Good luck!
PostPosted: Sat Aug 06, 2011 12:58 am
Thanks Greenlaw !
and another ...
do am I obliged to put the cameras at 2 m minimum height?
PostPosted: Sat Aug 06, 2011 3:07 am
First, I should make it clear that I've never used fewer than three PS3 Eye cameras, and that was a long time ago. After I upgraded to four (and later six) my results were significantly much better. I would not recommend using fewer than four.
As for camera height, I'm not sure where you got the info about '2 meters minimum height'. Here's is the official info from the Wiki:
http://www.ipisoft.com/en/wiki/index.ph ... cene_Setup
BTW, my cameras are staggered at various heights. I think most are about 2 meters, but I think at least one is closer to 1.5 meters and at least one is almost 3 meters high. That said, your own setup may be different depending on the size of your location.
PostPosted: Sat Aug 06, 2011 12:07 pm
Thank you Greenlaw
resolved
Users browsing this forum: No registered users and 56 guests
