It is currently Mon Oct 26, 2026 5:43 am
PostPosted: Mon Dec 12, 2011 11:48 pm
When I record with the 2 kinect cameras after 10secs or so it comes up with a buffer error and stops recording
Cra0kalo
Lead of Operation Reaper
http://projectreaper.com
PostPosted: Tue Dec 13, 2011 2:37 pm
Is that with RGB option enabled?
PostPosted: Tue Dec 13, 2011 2:56 pm
Na the RGB is off, after closing down some memory intense programs it seems it doesn't appear anymore.
Its to do with RAM i think
Cra0kalo
PostPosted: Wed Dec 14, 2011 1:47 am
i have the same problem with one my laptop. what is your memory amount? what programs did you closed?
PostPosted: Wed Dec 14, 2011 2:11 am
Do this
go to Start > run or in windows7 type in search
services.msc
hit enter
then go and stop all the proccess you think are not needed at that time so like for example "mentalray (64bit)" "Apple Mobile Support" etc
then go into taskmanger and end all the proccesses you don't need, be careful not to end system ones and your graphic card and ipi recorder.
Cra0kalo
PostPosted: Wed Dec 14, 2011 2:24 am
Users browsing this forum: Bing [Bot] and 102 guests
