ipisoft.com
https://forum.ipisoft.com/
dual kinect problem
https://forum.ipisoft.com/viewtopic.php?f=2&t=5927
Page 1 of 3
Author:  imansham [ Wed Mar 28, 2012 12:00 pm ]
Post subject:  dual kinect problem
hi
i want to use dual kinect for motion capture
but when i open my video there are 1 camera ! and i can't use Calibration . because there is not it's tab on IPI Studio ! Why ?!?!
What should I do?
Please Help Me
Author:  vmaslov [ Thu Mar 29, 2012 12:15 am ]
Post subject:  Re: dual kinect problem
When iPi Studio detects just 1 camera when opening video it means that video was shoot with 1 camera. Are you sure that both Kinects are available in iPi Recorder? Please consult with wiki http://wiki.ipisoft.com/IPi_Recorder_Installation_p2_Dual_Kinect
Calibration tab is not available for single Kinect configuration.
Btw your screenshots cannot be viewed with "HTTP 403 Forbidden" status.
Author:  imansham [ Thu Mar 29, 2012 3:05 am ]
yes when i use 1 kinect in ipi recorder my video frame size is : 640 * 480
and when i use dual kinect in ipi recorder my video frame size is : 1280*480
but in ipi studio there are 1 camera !
but when i use <<< Color video >>> or <<< Raw video >>> , i have 2 camera ! but when i select <<< Depth video (kinect) >>> , just have 1 camera !
i have screen shot :
http://img4up.com/up2/92077535432314537902.jpg
http://img4up.com/up2/51523133285931462554.jpg
http://img4up.com/up2/48051983805880141839.jpg
http://img4up.com/up2/13269748878110174131.jpg
plaase see this pictures.
my problem is not in IPI RECRODER ! that is in IPI Studio . when i open my kinect depth video into ipi studio , there are just 1 camera available ! and i cant use Calibration !
http://img4up.com/up2/39728571285022552178.jpg
http://img4up.com/up2/92784015284251425382.jpg
please help me
Author:  vmaslov [ Thu Mar 29, 2012 5:43 am ]
That's strange. Are you sure you are opening correct file which was recorded with 2 kinects?
Still cannot see screenshots from the links above. Got HTTP 403 error.
Author:  imansham [ Thu Mar 29, 2012 6:30 am ]
i'm upload my screen shot in other location <<< Uploadstation.com >>> and compress them into Rar format.
after download file. open it with winrar .
http://www.uploadstation.com/file/h5s86 ... _shots.rar
If you can't see pictures . use this link :
http://mtpi.org/p/1.jpg
http://mtpi.org/p/2.jpg
http://mtpi.org/p/3.jpg
http://mtpi.org/p/4.jpg
http://mtpi.org/p/5.jpg
http://mtpi.org/p/6.jpg
If you can't see pictures again . Tell me I'm upload them in other location again.
and im sure to opening file wich recorded with 2 kinects. and size of my video is 1280 * 480 .
oh , im tired .
Author:  imansham [ Thu Mar 29, 2012 2:36 pm ]
please help me :(
Author:  vmaslov [ Fri Mar 30, 2012 1:45 am ]
Ok. I've managed to download RAR file with screenshots. As I can see, you are using Kinects with OpenNI drivers (psdrv3).
First, you could try turn off recording of RGB in iPi Recorder (check "Dont't record RGB for depth sensors" under "advanced settings" in "Cameras Selector" dialog).
Next, you could switch to using MS Kinect SDK available for download at http://download.microsoft.com/download/E/E/2/EE2D29A1-2D5C-463C-B7F1-40E4170F5E2C/KinectSDK-v1.0-Setup.exe. You may be required also to uninstall "psrdv3" driver installed during iPi Recorder setup.
Can you also provide a screenshot of recorded video itself open in any video player? Better in some loseless image format: PNG or BMP.
Author:  imansham [ Fri Mar 30, 2012 3:23 am ]
i uninstalled openNI ... and installed SDK . and check "Dont't record RGB for depth sensors" . but My problem is not solved !
and just i have 1 camera in IPI studio !
see this screenshot , in <<< KM PLAYER >>> : http://uploaded.to/file/9nthplvm
video details :
frame width : 1280 * 480
frame rate : 30 frames/second
length : 00:00:07
Author:  vmaslov [ Fri Mar 30, 2012 3:54 am ]
The frame image you've provided seems quite ok. Can you provide the whole video file. You may record some very short (1s) video to reduce size.
Author:  imansham [ Fri Mar 30, 2012 4:30 am ]
downlaod this video :
http://uploaded.to/file/5z0fgmhl
Page 1 of 3 All times are UTC - 8 hours [ DST ]
http://www.phpbb.com/
