graphic card
https://forum.ipisoft.com/viewtopic.php?f=2&t=6019
Author:  aodusany [ Fri May 11, 2012 3:31 am ]
Post subject:  graphic card
I am thinking off getting a new graphic card. Because the cards which are suggested by ipisoft are not in the UK (similar type).
Would this card work fine with the ipi studio:
EVGA Nvivdia GTXTi 1GB 192-Bit 3D Ready Graphics Card
Product Features
Maximum graphic adapter memory: 1024 MB
Graphics adapter memory type: GDDR5-SDRAM
Memory bus: 192 bit
Memory clock speed: 4356 MHz
Memory bandwidth (max): 104.5 GB/s
Microsoft DirectX 11 support
Nvidia CUDA technology
Nvidia SLI ready
Nvidia 3D Vision Surround ready
Microsoft Windows 7 support
Technical Details
Core Clock: 951 Mhz;Memory Clock: 4356 MHz effective;Shader Clock: 1903 Mhz;CUDA Cores: 192;Bus Type: PCI-E 2.0;Memory Details: 1 Gb GDDR5;Memory Bit Width: 192 bit;Memory Speed: 0.5 ns;Memory Bandwidth: 104.5 Gb/sec.;Texture Fill Rate: 30.4 GT/s
Author:  vmaslov [ Fri May 11, 2012 5:49 am ]
Post subject:  Re: graphic card
I suppose you're talking about this model http://www.evga.com/products/moreInfo.asp?pn=01G-P3-1556-KR. Yes, it should be fine for motion tracking. I guess performance will be slightly lower than with the GTX 560 model listed at our site.
Author:  aodusany [ Fri May 11, 2012 10:15 am ]
thanks
Author:  aodusany [ Thu May 17, 2012 9:05 am ]
I purchased and fitted 'EVGA Nvivdia GTXTi 1GB 192-Bit 3D Ready Graphics Card' into my desktop today.
My goodness what a difference. The card I changed 'Nvidia Geforce 9500 GT' processed 2 kinects in ipi soft studio at between 6 and 7 seconds per frame.
With the new card fitted the 2 kinects are process between 1 second and 0.8 seconds per frame. What a difference, the new card is about 6 times faster.
To put in the new card I had to change my power supply unit (psu) which was 500w, the new psu is 750w. All seems to be working well :0)
Author:  Greenlaw [ Thu May 17, 2012 10:12 am ]
Yes, less waiting and more playing. :)
