[Q] Each single video using Dual Kinect configuration
https://forum.ipisoft.com/viewtopic.php?f=2&t=6145
Author:  hansu005 [ Mon Jun 25, 2012 2:11 pm ]
Post subject:  [Q] Each single video using Dual Kinect configuration
I want to compare the accuracy between Single and Dual Kinect configurations, using 2 Kinects (i.e., recording an actor simultaneously with two difference configurations, and comparing the results). Would it be possible to extract each video of the single Kinect when recording with a Dual Kinect configuration?
Or any idea for recording the same scene with both single and dual Kinect configuration, using only two Kinects?
Thank you very much for your help in advance.
Best,
Han.
Author:  vmaslov [ Tue Jun 26, 2012 4:28 am ]
Post subject:  Re: [Q] Each single video using Dual Kinect configuration
Hi, hansu005
I'll share with other users my suggestion made in our email talk.
To simultaneously record video from single- and dual-sensor configurations, you may start recording in parallel using two instances of iPiRecorder on the same computer. In one instance, you configure recording from sensor#1, and in the second instance - from sensor#1 and sensor#2. That is, sensor#1 is shared between two instances. This has been tested with ASUS Xtions and proved working. There is a good chance that this will works with Kinects also, because they have similar hardware to Xtions. Probably, it may be required to use PrimeSense drivers for Kinect to allow sharing one sensor between two instances of iPi Recorder.
