| Help with T- pose with two kinects https://forum.ipisoft.com/viewtopic.php?f=2&t=6176 |
| Author: | aodusany [ Tue Jul 17, 2012 1:26 am ] |
| Post subject: | Help with T- pose with two kinects |
Hi I have a problem: I set up the two kinects at about 90 degrees. Then I stand in front of one of them and make my T pose etc. I then go into studio 2: When I load the video for the t-pose, I am standing in the wrong position at at about 90 degree tuen to the screen avatar. Matching it up means I have to tun the avartar about 80 degrees clockwise to make it match the t-pose (this is the problem). Question is: (A) Should I stand square on to one of the kinects, if so which one? (B) If I have stood in front of one of the kinects (camera 1), and it loads in the studio turned from the avatar, is they a button or something that will change the presetence of the video to use the other kinect eg change camera 1 to camera 2 as main? OR what am I doing wrong? |
| Author: | vmaslov [ Tue Jul 17, 2012 5:36 am ] |
| Post subject: | Re: Help with T- pose with two kinects |
To minimize initial adjustments to actor model in Studio, you should strike the T-pose facing camera #1 (which is displayed first in Recorder when you are making a video). Actor model is also facing camera #1 in default position. |
| Author: | aodusany [ Wed Jul 18, 2012 12:44 am ] |
Can you change the #1 camera in the recorder to #2, so you do not have to move the kinect, or swap the usb connections around? |
| Author: | vmaslov [ Wed Jul 18, 2012 1:10 am ] |
You can change cameras order by dragging their images at the Setup stage. |
