 Post subject: standalone ipirecorder
PostPosted: Tue Sep 11, 2012 2:21 pm
hello there,
Can the ipi-recorder be installed and will it work without installing ipisoft? Sort of standalone?
I' ve tried to install ipirecorder, but when the ipirecorder is trying to install, it probably tries to make a connecting to the site...at that moment various sites with irrelevant data are popping up on my screen. Then the installer says that the ipirecorder cant being installed.
reason: when installing trial ipisoft at the same time to, I'm afraid that I run out of time in order to get a good view of the functions and getting it functioned without errors. It looks like a good program, but I want to use the 6 eye, which seems to be tricky to deal with. I just want to be sure that the program I'll buy is a seamless working program.
My system: i7 3770k, asus p8v77 pro motherboard with onboard graphic, win 7 64 bits, not yet an graphic-card but coming this week. Enough internal Gb, anda fast HHD.
Greeting Henri
PostPosted: Wed Sep 12, 2012 12:59 am
Absolutely, you can install iPi Recorder on any number of machines without the need for iPi Mocap Studio to be installed too. For example, you can use a laptop for recording because of its mobility, and do processing in Studio on a powerful desktop.
Depending on your choice of options to install, the installation program of iPi Recorder may download some stuff like .NET Framework 4 or Kinect SDK. But it does not open any websites in a browser. Also, after installation, iPi Recorder uses an Internet connection (if available) once a day to automatically check for updates. That's it - no other network related activity.
You can attach screenshots of what are you getting during installation, so we can do anything other then blind guess on your situation.
PostPosted: Sat Sep 22, 2012 1:52 am
Hello again,
Thanks for replying.
I have noticed that the recorder install sees my system as a win32 system, while its an win 7 64 bits system...maybe thats the problem?
Further, the popped up site are an attempt of trying to solve the problem with search on tagwords by Babylonsearch, I believe.
But maybe ther is something else going on
So, if this is the case, is there a version of ipirecorder that can work with 64 bits windows 7?
My error report (parts of it are in dutch):
INFO PLATFORMVERSIE
Windows : 6.1.7601.65536 (Win32NT)
Common Language Runtime : 4.0.30319.269
System.Deployment.dll : 4.0.30319.1 (RTMRel.030319-0100)
clr.dll : 4.0.30319.269 (RTMGDR.030319-2600)
dfdll.dll : 4.0.30319.1 (RTMRel.030319-0100)
dfshim.dll : 4.0.31106.0 (Main.031106-0000)
BRONNEN
Implementatie-url : file:///C:/Users/ANITA&~1/AppData/Local/Temp/%7BCE00670F-5BCE-4112-97CB-4D3C081716AC%7D/r/iPiRecorder.application
Toepassing-url : file:///C:/Users/ANITA&~1/AppData/Local/Temp/%7BCE00670F-5BCE-4112-97CB-4D3C081716AC%7D/r/Application%20Files/iPiRecorder_2_0_0_14/iPiRecorder.exe.manifest
IDENTITEITEN
Implementatie-identiteit : iPiRecorder.application, Version=2.0.0.14, Culture=neutral, PublicKeyToken=dd200afcf7b6b7ee, processorArchitecture=msil
Toepassingsidentiteit : iPiRecorder.exe, Version=2.0.0.14, Culture=neutral, PublicKeyToken=dd200afcf7b6b7ee, processorArchitecture=msil, type=win32
TOEPASSINGSSAMENVATTING
* Installeerbare toepassing.
FOUTSAMENVATTING
Hieronder ziet u een overzicht van de fouten. Verderop in het logboek vindt u nadere details over deze fouten.
* Er is een uitzondering opgetreden bij het vaststellen van vertrouwen. De volgende berichten voor mislukte acties zijn aangetroffen:
+ De waarde valt niet binnen het verwachte bereik.
* Activering van C:\Users\ANITA&~1\AppData\Local\Temp\{CE00670F-5BCE-4112-97CB-4D3C081716AC}\r\iPiRecorder.application heeft tot een uitzondering geleid. De volgende berichten voor mislukte acties zijn aangetroffen:
SAMENVATTING MISLUKTE TRANSACTIES ONDERDELENARCHIEF
Er zijn geen transactiefouten aangetroffen.
WAARSCHUWINGEN
Er werden geen waarschuwingen weergegeven bij deze bewerking.
VOORTGANGSSTATUS BEWERKING
* [22-9-2012 10:24:55] : De activering van C:\Users\ANITA&~1\AppData\Local\Temp\{CE00670F-5BCE-4112-97CB-4D3C081716AC}\r\iPiRecorder.application is gestart.
* [22-9-2012 10:25:01] : Verwerking van het implementatiemanifest is voltooid.
* [22-9-2012 10:25:01] : De installatie van de toepassing is gestart.
* [22-9-2012 10:25:01] : Verwerking van het toepassingsmanifest is voltooid.
* [22-9-2012 10:25:01] : Compatibele runtimeversie 4.0.30319 gevonden.
FOUTDETAILS
De volgende fouten zijn aangetroffen bij deze bewerking.
* [22-9-2012 10:25:01] System.ArgumentException
- De waarde valt niet binnen het verwachte bereik.
- Bron: mscorlib
- Stack-tracering:
bij System.Deployment.Internal.Isolation.IDefinitionAppId.EnumAppPath()
bij System.ActivationContext.CreateFromNameAndManifests(ApplicationIdentity applicationIdentity, String[] manifestPaths)
bij System.Deployment.Application.ActivationDescription.ToActivationContext()
bij System.Deployment.Application.ApplicationActivator.DownloadApplication(SubscriptionState subState, ActivationDescription actDesc, Int64 transactionId, TempDirectory& downloadTemp)
bij System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState& subState, ActivationDescription actDesc)
bij System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
bij System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
- Bron: mscorlib
- Stack-tracering:
TRANSACTIEDETAILS ONDERDELENARCHIEF
Er is geen transactie-informatie beschikbaar.
PostPosted: Sat Sep 22, 2012 1:40 pm
FYI, the computer I currently use iPi Recorder and iPi Studio is running under Windows 7 x64. Just to be clear, iPi DMC should run on either 32-bit or 64-bit computers but it runs in x32-bit mode under Windows 7 x64, which is normal.
Sorry, I'm not sure what the errors you're seeing mean. Hopefully somebody from iPi Soft can help soon.
PostPosted: Mon Sep 24, 2012 12:54 pm
Oke, now I know that it tje 64 bits issue is not the problem. Thanks for your response*
I have still not a clear view on whats the problem
The errorreport says:
+ De waarde valt niet binnen het verwachte bereik.!
translated:
* An exception occurred while establishing trust. The following messages for failed actions are detected:
+ The value is not within the expected range.
* Activation of has led to an exception. The following messages for failed actions are detected:
It seems to me that maybe the antivirus-program is denying the install of ipirecorder.
If no more suggetions come in by the forum then I ll try this week to install ipirecorder again with blocked antivirusprogram.
PostPosted: Thu Sep 27, 2012 1:12 am
I found that your problem is most probably related to bug in ClickOnce not loving some "special" characters in paths:
http://blogs.msdn.com/b/gauravb/archive ... sands.aspx
And you have an ampersand in your username, which is part of the installation path (C:\Users\<username\...). You should install under another user without an ampersand.
Correction. Recorder v2 already runs in 64-bit mode on Win x64.
PS. Sorry for a late pingback - I was ill.
PostPosted: Thu Sep 27, 2012 2:04 am
Sorry for my misinformation...and thank you for the correct info! I'm not sure how I missed that but that's good news! :)
Hope you're feeling better soon.
PostPosted: Thu Sep 27, 2012 8:16 am
Thank you vmaslov!
such a small character such a big issue.
Oke, never to old to learn.
Try it without ampersand in my name (a pity, I liked it)
But everything for the good case
Hope you feel more than 100% better.
All replyers: thanks for helping me out.
greetings Henri
