ipisoft.com
https://forum.ipisoft.com/
Can only see one camera in the viewport at the same time
https://forum.ipisoft.com/viewtopic.php?f=2&t=6721
Page 1 of 1
Author:  acrylic.cow [ Mon Jan 21, 2013 8:17 pm ]
Post subject:  Can only see one camera in the viewport at the same time
i have done a capture with 2 kinect. I hate sucessly done my calibration scene and now i am trying to do my first motion capture.
But, once i import my capture in ipi, i can only see one pointcloud at the time. I i click camera one, i see the front point cloud, if i click the second i see the back. But in the tutorial i watched the guy have both a the same time. Im i missing someting.
Also, is it possible to only export the pointcloud to maya for animation reference ? That could be a great too not for mation capture but for 3d animation reference.
Thks,
Fred
Author:  andrew [ Tue Jan 22, 2013 10:42 am ]
Post subject:  Re: Can only see one camera in the viewport at the same time
Hello,
Please, try the following menu items: View -> Show Depth from All Sensors and View -> Hide Background
Current version doesn't support this feature
Author:  acrylic.cow [ Tue Jan 22, 2013 11:25 am ]
Thanks i can now see it :)
Do you plan to implement this feature (the pointcloud export) ? That could be such an add-on to the software. Been able to do 3d Referencement for animator is a hudge deal. From what i see, that could even work for animal too. (Wich take wuite more time too animate)
Another question, I have seen on the website that the best support so far is with the ps eye. I consider to buy 2 prime camera (http://www.primesense.com/solutions/sensor/). I think they will work on your software. But will i get aswell the porformance increse from the hardware ?
Tanks again,
Fred
Author:  vmaslov [ Tue Jan 22, 2013 1:02 pm ]
First, only Carmine 1.08 should be considered as it is far range model.
It may be recognized by iPi Recorder as ASUS Xtion Live, as it works through the same OpenNI API and uses the same PrimeSense sensor (though probably newer revision of it). But there is no guarantee, as we have not tested it yet.
We have found this model recently and are just planning to order one item for testing. So we cannot say nothing about hardware performance.
Author:  acrylic.cow [ Tue Jan 22, 2013 1:47 pm ]
Thanks for the info, i guess i will try it aswell,
And for my first question, do you have already plan to create an export for maya (or other 3d software) ? Is it on your timeline ?
Thanks
Fred
Author:  vmaslov [ Wed Jan 23, 2013 12:49 am ]
No, currently. As adviced in other topic, you can use Brekel Pro PointCloud for that.
Author:  acrylic.cow [ Wed Jan 23, 2013 8:49 am ]
Ok thanks for the reference. I hope you will consider to implement it in your software because you can use 2 kinect. Wich give you full 360 degree reference.
Thanks !
Author:  vmaslov [ Mon Mar 18, 2013 10:37 am ]
PrimeSense Carmine sensors indeed work with previous versions recognized as ASUS Xtion Live.
Now we have tested them ourselves and introduce official support in iPi Recorder 2.1.4.21.
http://www.phpbb.com/
